[GRASS-dev] [GRASS GIS] #2078: New tool: Ability to draw a region (computation range) from the map display module
GRASS GIS trac at osgeo.org
Sun Sep 15 04:17:46 PDT 2013
module
 Reporter:  vesnikos     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.4
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:               |    Platform:  All
      Cpu:  All          |
 The ability to mark the computational range to perform revelant algorithms
 in only parts of the map im intrested of will really help speed up my
 workflow.
 At the momment there is the option to set the region from current display
 extents (through the zoom option button), but there is not any way to
 visualy mark the region I am intrested in by drawing a rectangle (to get
 the extents)  for example.
 You can also set the region manually with g.region but its prone to human
 error (you can easily miss a digit)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2078>
