[GRASS-dev] [GRASS GIS] #1941: wxGUI fails with Japanese locale --> mixed Python installs on Windows
GRASS GIS trac at osgeo.org
Sun Sep 15 10:32:51 PDT 2013
 Reporter:  venkat    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  7.0.0
Component:  wxGUI     |     Version:  svn-trunk
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-32    |
Comment(by annakrat):
 Replying to [comment:31 martinl]:
 > Replying to [comment:29 hellik]:
 > > > it helped, GRASS now starts, python scripts called from command line
 also starts. My suggestion is to apply patches r57639 and r57646 also in
 GRASS 6.x, ie. to remove `extralib` directory from standalone installer.
 Any objections?
 > > +1 for backport
 > patch applied in all active branches, now GRASS should start without
 'MAX_REPEAT' problem.
 Thanks a lot, there is a ticket already discussing this problem (#2039) so
 let's move the discussion there and leave this for Japanese locale.
 Venka, can you please test it now again when the unrelated MAXREPEAT
 problem should be fixed?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1941#comment:32>
