[GRASS-dev] [GRASS GIS] #2014: r.sun using EPSG:3031 projection gives strange results
trac at osgeo.org
Sun Sep 15 16:32:11 PDT 2013
Reporter: pierreroudier | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.sun | Platform: Linux
Cpu: x86-64 |
Comment(by pierreroudier):
Hamish,
The original command I used was:
## annual beam radiance
DEM=rsr_dem
# setup region, and re-compute slope in deg.
g.region rast=$DEM res=200 -ap
#g.region res=200 n=-567200 s=-634800 w=-3400 e=117600 -ap
r.slope.aspect --o elev=$DEM slope=slope_deg aspect=aspect
# setup: no accomodation for Linke, using defaults
BEGIN=1
END=365
STEP=1
NUM_CORES=4
for DAY in `seq $BEGIN $STEP $END` ; do
DAY_STR=`echo $DAY | awk '{printf("%.03d", $1)}'`
echo "Processing day $DAY_STR at `date` ..."
echo "Processing day $DAY_STR at `date` ...\n" >> r.sun_progress.txt
CMD="r.sun --o --quiet \
elev_in=$DEM slope_in=slope_deg asp_in=aspect \
step=1.0 \
day=$DAY \
beam_rad=beam_rad.$DAY_STR \
insol_time=insol_time.$DAY_STR "
# poor man's multi-threading for a multi-core CPU
MODULUS=`echo "$DAY $STEP $NUM_CORES" | awk '{print $1 % ($2 * $3)}'`
if [ "$MODULUS" = "$STEP" ] ; then
# stall to let the background jobs finish
$CMD
sleep 2
else
$CMD &
fi
done
# combine into annual sum
r.series --o in=`g.mlist type=rast pattern="beam_rad.*" sep=","`
out=beam_rad_annual method=sum
r.series --o in=`g.mlist type=rast pattern="insol_time.*" sep=","`
out=insol_time_annual method=sum
# convert to MJ/sq. m
# r.sun mode 2 * (3600 / 100000) ==> MJ/sq. m
r.mapcalc --o "beam_rad_annual_mj = beam_rad_annual * (3600.0 / 100000.0)"
r.colors.stddev beam_rad_annual_mj
# clean-up
# g.mremove -f rast=beam_rad.*
# g.mremove -f rast=insol_time.*
Happy to assist with the testing on grass7. Which Antarctic projection
would you suggests? I got no projection in mind that would suit our needs.
Pierre
BTW the screenshot was generated in QGIS, not GRASS, so that's one less
bug to fix :)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2014#comment:7>
