[GRASS-dev] [GRASS GIS] #2080: wxGUI: changing properties of barscale or legend
GRASS GIS trac at osgeo.org
Mon Sep 16 01:52:06 PDT 2013
 Reporter:  martinl      |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  unspecified
 Keywords:  decorations  |    Platform:  Unspecified
      Cpu:  Unspecified  |
 when changing properties of barscale or legend you need to go through two
 dialogs. The first dialog allows to disable/enable decoration and launch
 properties (autogenerated) dialog. Here 'Apply' button has no effect, so
 you cannot see immediately the change. You close the properties dialog and
 then the first dialog. After these steps decoration is re-rendered.
 My suggestion is to avoid the first dialog. Clicking on decoration would
 launch properties dialog immediately. Right click shows contextual menu
 with one item 'Hide'. To show decoration you would go to the toolbar and
 to add selected decoration again. Or global contextual menu (which has
 currently only one item 'Copy to clipboard..') could have item to
 'Show/hide barscale', 'Show/hide legend', ...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2080>
