[GRASS-dev] [GRASS GIS] #2083: Add 3D raster (volume) support to d.legend
GRASS GIS trac at osgeo.org
Thu Sep 19 20:09:44 PDT 2013
 Reporter:  wenzeslaus         |       Owner:  grass-dev@…
     Type:  enhancement        |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  Display            |     Version:  svn-trunk
 Keywords:  d.legend raster3d  |    Platform:  All
      Cpu:  All                |
 It is not possible to show a legend for 3D raster map.
 I have a patch to add support for 3D rasters into `d.legend` module. It is
 created in the same way as `r3.colors`, i.e. main.c is turned to the
 normal C file and there are two new C files with `int main` functions
 which calls the same function but with different parameter.
 I used the names `d.legend` and `d.rast3d.legend`.
 I'm not sure about non-floating point 3D rasters. There are no integers
 but categories are supported? There is actually no documentation about
 data types in 3D (see
 [http://grass.osgeo.org/grass70/manuals/raster3dintro.html user] and
 [http://grass.osgeo.org/programming7/raster3dlib.html programming]
 manuals).
 The documentation and some comments are still missing but I will add them.
 Some basic test would be nice too. The wxGUI support for this will be
 added later.
 To test the legend use:
 # generate data
 r3.mapcalc "test_1 = "
 # set some color table
 r3.colors map=test_1 color=elevation
 # use non-gui monitor
 # try some legends
 d.rast3.legend map=test_1 at=10,50,10,20
 d.rast3.legend map=test_1 at=10,50,30,40 use=10,20,50
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083>
