[GRASS-dev] Script directory in build GRASS session
Helena Mitasova
hmitaso at ncsu.edu
Sun Sep 22 20:41:39 PDT 2013
On Sep 22, 2013, at 11:04 PM, Vaclav Petras wrote:
> I added the script directory into PATH for build session, see r57814.
> This makes sense (bin is there too) and moreover it should fix missing descriptions and keywords for modules in wxGUI menu and module tree. Note that you wouldn't saw this problem if gui/wxpython is compiled in (standard) GRASS session. Maybe this change will fix menudata.xml problem for Micheal's compilation, but I'm afraid that it will not.
I just updated grass7 and the problem is still there for MacOSX10.6.
I assume that Michael refers to these
> Errors in:
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/animation
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/mapswipe
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/gmodeler
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/rlisetup
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/psmap
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/dbmgr
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/vdigit
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/iclass
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/gcp
> /Users/helena/grassdev7/grass_trunk/gui/wxpython/timeline
Helena
> Vaclav
> https://trac.osgeo.org/grass/changeset/57814
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
