[GRASS-dev] [GRASS GIS] #2014: r.sun using EPSG:3031 projection gives strange results
trac at osgeo.org
Tue Sep 24 22:13:59 PDT 2013
Reporter: pierreroudier | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.sun | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
Hi, fwiw after fixing a small bug in r.sunmask I was able to write a
script to show the sun's position through the day on a polar graph.
Plot is for Jan 1st 00:00-23:45 (gap in the plot is 23:45-24:00) around
Ross Island in Antarctica (McMurdo & Scott Bases) in a polar stereographic
location (epsg:3286). Red "+" are the 15 minute marks. So the more sun in
the south effect seems to be a combination of midnight shade on the north
slope, sun peeking over the ridges onto the south slope at midday, and the
cumulative time the Sun spends in the south at this time of year- the
azimuth is not strictly going around at 15deg/hour.
d.histogram of a r.slope.aspect slope map shows most of Erebus between 4
and 17 deg, very little over 25 deg, and a max of 35deg. So midday sun at
35.5 deg above the horizon would generally get to the south slope, even if
the shallow angle meant that little of it would be hitting it with much
impact.
so it's all about the cumulative timing & the tortoise beats the hare.
Hamish
The r.sunmask module can calculate the position of the Sun in the sky
throughout the day:
for HOUR in `seq -f'%02.0f' 0 23` ; do
for MINUTE in 00 15 30 45 ; do
r.sunmask -sg elev=ramp200dem_wgs_v2.ross_island out=dummy \
year=2013 month=1 day=1 hour=$HOUR minute=$MINUTE second=0 \
timezone=12 \
> "solar_pos.hour_$HOUR.$MINUTE.txt"
done
done
grep sun solar_pos.hour_* | grep -v set | grep -v rise > solar_pos.day
grep above solar_pos.day | cut -f2 -d= > angleabove.txt
grep azim solar_pos.day | cut -f2 -d= > azimuth.txt
% matlab or octave
load azimuth.txt
load angleabove.txt
polar(azimuth * pi/180, angleabove)
hold on
polar(azimuth * pi/180, angleabove, 'r+')
set(gca, 'View', [90 -90]) % rotate so 0 deg as north-up not +x axis
Ticket URL: <https://trac.osgeo.org/grass/ticket/2014#comment:9>
