[GRASS-dev] [GRASS GIS] #2085: build failure on s390s
GRASS GIS trac at osgeo.org
Thu Sep 26 15:12:25 PDT 2013
 Reporter:  hamish     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  6.4.4
Component:  LibVector  |     Version:  6.4.3
 Keywords:  s390x      |    Platform:  Linux
      Cpu:  Other      |
 there was an error building the 6.4.3 Debian package on the IBM s390x
 platform. Was a similar error seen in trunk during the recent AIX fixes?
 It happens in the lib/vector/diglib/ make test.
 full build log:
 https://buildd.debian.org/status/fetch.php?pkg=grass&arch=s390x&ver=6.4.3-2&stamp=1380196757
 gcc -I/build/buildd-grass_6.4.3-2-s390x-BE2gjV/grass-6.4.3/dist.s390x-ibm-
 linux-gnu/include  -g -O2 -fstack-protector --param=ssp-buffer-size=4
 -Wformat -Werror=format-security  -fPIE  -fstack-protector --param ssp-
 buffer-size=4  -D_FORTIFY_SOURCE=2  -Wformat -Wformat-security -Werror
 =format-security  -Wno-error=format-security -Wall -O    -fPIC
 -DPACKAGE=\""grasslibs"\" -I/usr/include/gdal -I/usr/include
 -DPACKAGE=\""grasslibs"\"  -I/build/buildd-grass_6.4.3-2-s390x-
 BE2gjV/grass-6.4.3/dist.s390x-ibm-linux-gnu/include -o OBJ.s390x-ibm-
 linux-gnu/spindex_rw.o -c spindex_rw.c
 spindex_rw.c: In function 'dig_Wr_spindx_head':
 spindex_rw.c:38:5: warning: pointer targets in passing argument 1 of
 'dig__fwrite_port_C' differ in signedness [-Wpointer-sign]
 /build/buildd-grass_6.4.3-2-s390x-BE2gjV/grass-6.4.3/dist.s390x-ibm-linux-
 gnu/include/grass/vect/dig_externs.h:64:5: note: expected 'char *' but
 argument is of type 'unsigned char *'
 spindex_rw.c:47:5: warning: pointer targets in passing argument 1 of
 spindex_rw.c: In function 'dig_Rd_spindx_head':
 spindex_rw.c:89:5: warning: pointer targets in passing argument 1 of
 'dig__fread_port_C' differ in signedness [-Wpointer-sign]
 gnu/include/grass/vect/dig_externs.h:57:5: note: expected 'char *' but
 spindex_rw.c:136:5: warning: pointer targets in passing argument 1 of
 spindex_rw.c: In function 'rtree_dump_branch':
 spindex_rw.c:177:28: warning: cast from pointer to integer of different
 size [-Wpointer-to-int-cast]
 spindex_rw.c: In function 'rtree_write_branch':
 spindex_rw.c:232:6: warning: cast from pointer to integer of different
 spindex_rw.c: In function 'rtree_read_branch':
 spindex_rw.c:297:13: warning: cast to pointer from integer of different
 size [-Wint-to-pointer-cast]
 linux-gnu/struct_alloc.o -c struct_alloc.c
 linux-gnu/type.o -c type.c
 linux-gnu/update.o -c update.c
 gcc -shared -o /build/buildd-grass_6.4.3-2-s390x-BE2gjV/grass-6.4.3/dist
 .s390x-ibm-linux-gnu/lib/libgrass_dig2.6.4.3.so -L/build/buildd-
 grass_6.4.3-2-s390x-BE2gjV/grass-6.4.3/dist.s390x-ibm-linux-gnu/lib -Wl
 ,--export-dynamic -Wl,-rpath-link,/build/buildd-grass_6.4.3-2-s390x-
 BE2gjV/grass-6.4.3/dist.s390x-ibm-linux-gnu/lib    OBJ.s390x-ibm-linux-
 gnu/allocation.o OBJ.s390x-ibm-linux-gnu/angle.o OBJ.s390x-ibm-linux-
 gnu/box.o OBJ.s390x-ibm-linux-gnu/cindex.o OBJ.s390x-ibm-linux-
 gnu/cindex_rw.o OBJ.s390x-ibm-linux-gnu/file.o OBJ.s390x-ibm-linux-
 gnu/frmt.o OBJ.s390x-ibm-linux-gnu/head.o OBJ.s390x-ibm-linux-gnu/inside.o
 OBJ.s390x-ibm-linux-gnu/linecros.o OBJ.s390x-ibm-linux-gnu/line_dist.o OBJ
 .s390x-ibm-linux-gnu/list.o OBJ.s390x-ibm-linux-gnu/plus.o OBJ.s390x-ibm-
 linux-gnu/plus_area.o OBJ.s390x-ibm-linux-gnu/plus_line.o OBJ.s390x-ibm-
 linux-gnu/plus_node.o OBJ.s390x-ibm-linux-gnu/plus_struct.o OBJ.s390x-ibm-
 linux-gnu/poly.o OBJ.s390x-ibm-linux-gnu/port_init.o OBJ.s390x-ibm-linux-
 gnu/portable.o OBJ.s390x-ibm-linux-gnu/prune.o OBJ.s390x-ibm-linux-
 gnu/spindex.o OBJ.s390x-ibm-linux-gnu/spindex_rw.o OBJ.s390x-ibm-linux-
 gnu/struct_alloc.o OBJ.s390x-ibm-linux-gnu/type.o OBJ.s390x-ibm-linux-
 gnu/update.o -lgrass_gis.6.4.3 -lgrass_datetime.6.4.3 -lz
 -lgrass_rtree.6.4.3 -lm
 (cd /build/buildd-grass_6.4.3-2-s390x-BE2gjV/grass-6.4.3/dist.s390x-ibm-
 linux-gnu/lib; ln -f -s libgrass_dig2.6.4.3.so /build/buildd-grass_6.4.3-2
 -s390x-BE2gjV/grass-6.4.3/dist.s390x-ibm-linux-gnu/lib/libgrass_dig2.so)
 /usr/bin/make OBJ.s390x-ibm-linux-gnu/test
 make[6]: Entering directory `/build/buildd-grass_6.4.3-2-s390x-
 BE2gjV/grass-6.4.3/lib/vector/diglib'
 echo "==============TEST============="
 gcc -L/build/buildd-grass_6.4.3-2-s390x-BE2gjV/grass-6.4.3/dist.s390x-ibm-
 linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-link,/build/buildd-
 grass_6.4.3-2-s390x-BE2gjV/grass-6.4.3/dist.s390x-ibm-linux-gnu/lib     -g
 -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-
 security  -fPIE  -fstack-protector --param ssp-buffer-size=4
 -D_FORTIFY_SOURCE=2  -Wformat -Wformat-security -Werror=format-security
 -Wno-error=format-security -Wall -O   -I/usr/include/gdal -I/usr/include
 linux-gnu/include  -o OBJ.s390x-ibm-linux-gnu/test test.c
 -lgrass_dig2.6.4.3 -lgrass_gis.6.4.3 -lgrass_datetime.6.4.3 -lz
 -lgrass_rtree.6.4.3  -lgrass_rtree.6.4.3 \
 -lz     -lgrass_datetime.6.4.3 -lm  -lz
 cd OBJ.s390x-ibm-linux-gnu; LD_LIBRARY_PATH=":/build/buildd-grass_6.4.3-2
 -s390x-BE2gjV/grass-6.4.3/dist.s390x-ibm-linux-gnu/lib" ./test; diff
 ./test.tmp ../test.ok
 Killed
 make[6]: *** [OBJ.s390x-ibm-linux-gnu/test] Error 2
 make[5]: *** [default] Error 2
 Binary files ./test.tmp and ../test.ok differ
 make[6]: Leaving directory `/build/buildd-grass_6.4.3-2-s390x-
 make[5]: Leaving directory `/build/buildd-grass_6.4.3-2-s390x-
 /usr/bin/make -C Vlib || echo /build/buildd-grass_6.4.3-2-s390x-
 BE2gjV/grass-6.4.3/lib/vector/Vlib >> /build/buildd-grass_6.4.3-2-s390x-
 BE2gjV/grass-6.4.3/error.log
 or was the build system just out of RAM? It was happening in 6.4.1 too,
 see http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=672719
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2085>
