[GRASS-dev] [GRASS GIS] #2088: G7: digitizer python error
trac at osgeo.org
Fri Sep 27 00:28:29 PDT 2013
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: digitizer, python | Platform: Linux
Cpu: x86-64 |
The wxGUI digitizer shows this problem:
File "/home/neteler/grass70/dist.x86_64-unknown-linux-
gnu/etc/gui/wxpython/mapwin/buffered.py", line 1025, in
MouseActions
self.OnLeftUp(event)
gnu/etc/gui/wxpython/mapwin/buffered.py", line 1206, in
OnLeftUp
self._onLeftUp(event)
gnu/etc/gui/wxpython/vdigit/mapwindow.py", line 850, in
_onLeftUp
self.OnLeftUpCopyLine(event)
gnu/etc/gui/wxpython/vdigit/mapwindow.py", line 758, in
OnLeftUpCopyLine
nselected = self.bdigit.GetDisplay().SelectLinesByBox((pos1,
pos2))
AttributeError
'VDigitWindow' object has no attribute 'bdigit'
To reproduce it:
* NC location
* load and show the "geology" map
* start the digitizer from the map display window
* create a new vector map
Note: the "geology" map disappears, "Render map" icon shows it again
* From "Additional tools": select "Copy feature from (background) vector
map
The error message appears (see above).
Furthermore there is no dialog from which vector map the user could copy
from (should be one of the maps loaded into the layer manager).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2088>
