[GRASS-dev] [GRASS GIS] #2086: libgis build failure on alpha
GRASS GIS trac at osgeo.org
Fri Sep 27 00:49:34 PDT 2013
 Reporter:  hamish         |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:  6.4.4
Component:  Compiling      |     Version:  6.4.3
 Keywords:  alpha, libgis  |    Platform:  Linux
      Cpu:  Other          |
Comment(by glynn):
 Replying to [ticket:2086 hamish]:
 > there was an error building the 6.4.3 Debian package on the Alpha
 platform.
 > it happens when linking libgis:
 (Copied from #2085)
 Alpha seems to have problems with function pointers in shared libraries.
 This may just be an issue with the linker flags for shared libraries (it
 probably doesn't help that Shlib.make expects the variable to be called
 SHLIB_LDFLAGS when 6.x's Platform.make uses SHLIB_LD_FLAGS).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2086#comment:1>
