[GRASS-dev] compiling 7.0 on MacOS 10.9
Vaclav Petras
wenzeslaus at gmail.com
Thu Apr 3 17:21:28 PDT 2014
On Wed, Apr 2, 2014 at 5:47 PM, epi <massimodisasha at gmail.com> wrote:
> https://trac.osgeo.org/grass/changeset/59485 (modify Rules.make to fix
> build_modules_xml.py on Windows (TODO: replace this workaround))
> http://lists.osgeo.org/pipermail/grass-dev/2014-March/067876.html (get
> interface description for python modules on Windows)
> > the wx dialog for (most but not all **) the grass modules, works fine.
>> ** command like g.region, r.mask and others do not lunch a gui dialog
>> when type their name in the grass shell.
>> This is actually standard behavior. Probably not documented well. This is
> how g.region parameters are handled. Use `g.region --ui`.
> i was aware that’s the standard behavior, but i found it a bit incoherent
> compared with what the other modules do.
> Is there any reason for that ?
If you think it is wrong or badly documented, you should open separate
thread for it and not confuse it compilation issues. If you decide to do
so, do a mailing list and Trac issues search beforehand.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140403/c049e3fa/attachment.html>
