[GRASS-dev] [GRASS GIS] #2242: Decide the destiny of r3.mkdspf and r3.showdspf modules
GRASS GIS trac at osgeo.org
Thu Apr 3 20:36:27 PDT 2014
 Reporter:  wenzeslaus   |       Owner:  grass-dev@…
     Type:  task         |      Status:  new
 Priority:  trivial      |   Milestone:  7.1.0
Component:  Raster3D     |     Version:  svn-trunk
 Keywords:  raster3D     |    Platform:  Unspecified
      Cpu:  Unspecified  |
 `r3.mkdspf` description:
 > Creates a display file from an existing grid3 file according to
 specified threshold levels. The display file is a display list of polygons
 that represent isosurfaces of the data volume. If specific levels are
 given, additional optional parameters are ignored. Min or max may be used
 alone or together to specify a sub-range of the data. The step parameter
 is given precedence over tnum.
 `r3.showdspf` description:
 > Visualization program which loads the isosurfaces previously calculated
 using `r3.mkdspf` and displays them according to commands given at the
 prompt. `r3.mkdspf` creates a dspf file from the 3D raster and
 `r3.showdspf` uses this dspf file to draw isosurfaces and 3D raster map to
 draw planes and everything related (boxes, etc).
 Please collect info about their features, usage, issues and most
 importantly replacements here. Open new ticket(s) if some functionality is
 missing and needs to be implemented.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2242>
