[GRASS-dev] GRASS 7 not finding gettext
Michael Barton Michael.Barton at asu.edu
Fri Apr 4 10:00:46 PDT 2014
So here is a test that I ran for William that suggests that there are indeed 2 architectures compiled into gettext.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ  85287-2402
USA
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www:  http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
Begin forwarded message:
From: Michael Barton <michael.barton at asu.edu<mailto:michael.barton at asu.edu>>
Subject: Re: [SPAM?] Re: GRASS 7 not finding gettext
Date: April 3, 2014 at 5:16:02 PM MST
To: Kyngesburye William <kyngchaos at kyngchaos.com<mailto:kyngchaos at kyngchaos.com>>
Cc: Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>>
The following with my old installation and the new compilations of today:
/usr/local/lib/libintl.dylib: Mach-O universal binary with 2 architectures
/usr/local/lib/libintl.dylib (for architecture x86_64): Mach-O 64-bit dynamically linked shared library x86_64
/usr/local/lib/libintl.dylib (for architecture i386): Mach-O dynamically linked shared library i386
Michael
C. Michael Barton
USA
On Apr 3, 2014, at 5:11 PM, William Kyngesburye <kyngchaos at kyngchaos.com> wrote:
what doe you get with
file /usr/local/lib/libintl.dylib
On Apr 3, 2014, at 7:08 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
Hmm.
I had no problem with compiling GRASS when I last did it in February.
When I just now recompiled gettext (current version), I used the same setup I did before, except that I’ve limited it to OSX 10.7 and above.
export MACOSX_DEPLOYMENT_TARGET=10.7
./configure --prefix=/usr/local --disable-dependency-tracking --disable-java --disable-libasprintf CFLAGS="-Os -arch x86_64 -arch i386 -fno-common -isysroot /Developer/SDKs/MacOSX10.7.sdk”
make
sudo make install
MIchael
C. Michael Barton
USA
On Apr 3, 2014, at 4:48 PM, William Kyngesburye <kyngchaos at kyngchaos.com> wrote:
It looks like your gettext/libintl is missing 32bit arch.
On Apr 3, 2014, at 4:16 PM, Michael Barton <michael.barton at asu.edu> wrote:
I don’t know what has changed, but I just recompiled gettext and redid configure. It still does not find gettext.
The configure flag I’m using is --with-nls
That’s still correct, right?
Here is the error:
checking whether to use NLS... yes
checking for gettext... no
checking for gettext in -lintl... no
configure: error: *** Unable to locate gettext() function.
Here is what seems to be the right place from configure.log
; return 0; }
configure:11940: checking whether to use FreeType
configure:11959: checking for location of FreeType includes
configure:11985: checking for ft2build.h
configure:11993: gcc -E  -I/Library/Frameworks/FreeType.framework/unix/include/freetype2 -I/Library/Frameworks/FreeType.framework/unix/include  conftest.c >/dev/null 2>conftest.out
configure:12027: checking for location of FreeType library
configure:12052: checking for FT_Init_FreeType in -lfreetype
configure:12069: gcc -o conftest -g -O2   -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk   -L/Library/Frameworks/FreeType.framework/unix/lib   -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk  conftest.c -lfreetype   1>&5
configure:12110: checking whether to use NLS
configure:12130: checking for gettext
configure:12156: gcc -o conftest -g -O2   -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk    -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk  conftest.c  1>&5
Undefined symbols for architecture i386:
"_gettext", referenced from:
 _main in conftest-qEjAiU.o
ld: symbol(s) not found for architecture i386
clang: error: linker command failed with exit code 1 (use -v to see invocation)
configure: failed program was:
#line 12133 "configure"
#include "confdefs.h"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char gettext(); below.  */
#include <assert.h>
/* Override any gcc2 internal prototype to avoid an error.  */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply.  */
char gettext();
int main() {
/* The GNU C library defines this for functions which it implements
to always fail with ENOSYS.  Some functions are actually named
something starting with __ and the normal name is an alias.  */
#if defined (__stub_gettext) || defined (__stub___gettext)
choke me
#else
gettext();
#endif
; return 0; }
configure:12174: checking for gettext in -lintl
configure:12191: gcc -o conftest -g -O2   -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk    -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk  conftest.c -lintl   1>&5
ld: library not found for -lintl
#line 12180 "configure"
char gettext();
int main() {
gettext()
; return 0; }
Michael
C. Michael Barton
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Apr 3, 2014, at 12:07 PM, Markus Neteler <neteler at osgeo.org> wrote:
On Thu, Apr 3, 2014 at 8:16 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
I'm trying to compile GRASS 7 RB.
Something has changed with the configuration checks so that it no longer can
find my installation of gettext. It worked OK on 3 January 2014, the last
time I compiled GRASS 7.
It must be a local problem: the configure* files have not been
modified for 7+ months:
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0
See the "config.log" files for any errors.
Markus
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140404/abe9d761/attachment-0001.html>
