[GRASS-dev] [SPAM?] Re: GRASS 7 not finding gettext
Michael Barton Michael.Barton at asu.edu
Fri Apr 4 21:27:00 PDT 2014
Would the general flags be --with-libs=/usr/local/lib  --with-includes=/usr/local/include ??
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 	480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Apr 4, 2014, at 7:57 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I think you need to ignore the first error about the missing symbol for i386 - it's testing for gettext in the system library(s), not libintl, and that will fail on OS X, it's just odd that it didn't also report the error for x86_64.
> The next error, where it can't find libintl, is more helpful.  This is testing for libintl in the system library paths.  I think in the past this has included /usr/local/lib, but it appears now it does not.  Maybe a change in a recent Xcode/clang update.
> I think there is a general lib and include flag for GRASS configure, you could try adding /usr/local/lib and /usr/local/include to that.
> On Apr 4, 2014, at 12:00 PM, Michael Barton <michael.barton at asu.edu> wrote:
>> So here is a test that I ran for William that suggests that there are indeed 2 architectures compiled into gettext.
>> Michael
>> ______________________________
>> C. Michael Barton
>> Tempe, AZ  85287-2402
>> USA
>> voice:
>> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
>> www:
>> http://csdc.asu.edu, http://shesc.asu.edu
>> Begin forwarded message:
>>> From: Michael Barton <michael.barton at asu.edu>
>>> Subject: Re: [SPAM?] Re: GRASS 7 not finding gettext
>>> Date: April 3, 2014 at 5:16:02 PM MST
>>> To: Kyngesburye William <kyngchaos at kyngchaos.com>
>>> Cc: Markus Neteler <neteler at osgeo.org>
>>> The following with my old installation and the new compilations of today:
>>> /usr/local/lib/libintl.dylib: Mach-O universal binary with 2 architectures
>>> /usr/local/lib/libintl.dylib (for architecture x86_64):
>>> Mach-O 64-bit dynamically linked shared library x86_64
>>> /usr/local/lib/libintl.dylib (for architecture i386):
>>> Mach-O dynamically linked shared library i386
>>> Michael
>>> C. Michael Barton
>>> USA
>>> www: http://csdc.asu.edu, http://shesc.asu.edu
>>> On Apr 3, 2014, at 5:11 PM, William Kyngesburye <kyngchaos at kyngchaos.com> wrote:
>>>> what doe you get with
>>>> file /usr/local/lib/libintl.dylib
>>>> On Apr 3, 2014, at 7:08 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>>> Hmm.
>>>>> I had no problem with compiling GRASS when I last did it in February.
>>>>> When I just now recompiled gettext (current version), I used the same setup I did before, except that I’ve limited it to OSX 10.7 and above.
>>>>> export MACOSX_DEPLOYMENT_TARGET=10.7
>>>>> ./configure --prefix=/usr/local --disable-dependency-tracking --disable-java --disable-libasprintf CFLAGS="-Os -arch x86_64 -arch i386 -fno-common -isysroot /Developer/SDKs/MacOSX10.7.sdk”
>>>>> make
>>>>> sudo make install
>>>>> MIchael
>>>>> C. Michael Barton
>>>>> USA
>>>>> On Apr 3, 2014, at 4:48 PM, William Kyngesburye <kyngchaos at kyngchaos.com> wrote:
>>>>>> It looks like your gettext/libintl is missing 32bit arch.
>>>>>> On Apr 3, 2014, at 4:16 PM, Michael Barton <michael.barton at asu.edu> wrote:
>>>>>>> I don’t know what has changed, but I just recompiled gettext and redid configure. It still does not find gettext.
>>>>>>> The configure flag I’m using is --with-nls
>>>>>>> That’s still correct, right?
>>>>>>> Here is the error:
>>>>>>> checking whether to use NLS... yes
>>>>>>> checking for gettext... no
>>>>>>> checking for gettext in -lintl... no
>>>>>>> configure: error: *** Unable to locate gettext() function.
>>>>>>> Here is what seems to be the right place from configure.log
>>>>>>> ; return 0; }
>>>>>>> configure:11940: checking whether to use FreeType
>>>>>>> configure:11959: checking for location of FreeType includes
>>>>>>> configure:11985: checking for ft2build.h
>>>>>>> configure:11993: gcc -E  -I/Library/Frameworks/FreeType.framework/unix/include/freetype2 -I/Library/Frameworks/FreeType.framework/unix/include  conftest.c >/dev/null 2>conftest.out
>>>>>>> configure:12027: checking for location of FreeType library
>>>>>>> configure:12052: checking for FT_Init_FreeType in -lfreetype
>>>>>>> configure:12069: gcc -o conftest -g -O2   -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk   -L/Library/Frameworks/FreeType.framework/unix/lib   -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk  conftest.c -lfreetype   1>&5
>>>>>>> configure:12110: checking whether to use NLS
>>>>>>> configure:12130: checking for gettext
>>>>>>> configure:12156: gcc -o conftest -g -O2   -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk    -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk  conftest.c  1>&5
>>>>>>> Undefined symbols for architecture i386:
>>>>>>> "_gettext", referenced from:
>>>>>>> _main in conftest-qEjAiU.o
>>>>>>> ld: symbol(s) not found for architecture i386
>>>>>>> clang: error: linker command failed with exit code 1 (use -v to see invocation)
>>>>>>> configure: failed program was:
>>>>>>> #line 12133 "configure"
>>>>>>> #include "confdefs.h"
>>>>>>> /* System header to define __stub macros and hopefully few prototypes,
>>>>>>> which can conflict with char gettext(); below.  */
>>>>>>> #include <assert.h>
>>>>>>> /* Override any gcc2 internal prototype to avoid an error.  */
>>>>>>> /* We use char because int might match the return type of a gcc2
>>>>>>> builtin and then its argument prototype would still apply.  */
>>>>>>> char gettext();
>>>>>>> int main() {
>>>>>>> /* The GNU C library defines this for functions which it implements
>>>>>>> to always fail with ENOSYS.  Some functions are actually named
>>>>>>> something starting with __ and the normal name is an alias.  */
>>>>>>> #if defined (__stub_gettext) || defined (__stub___gettext)
>>>>>>> choke me
>>>>>>> #else
>>>>>>> gettext();
>>>>>>> #endif
>>>>>>> ; return 0; }
>>>>>>> configure:12174: checking for gettext in -lintl
>>>>>>> configure:12191: gcc -o conftest -g -O2   -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk    -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk  conftest.c -lintl   1>&5
>>>>>>> ld: library not found for -lintl
>>>>>>> #line 12180 "configure"
>>>>>>> char gettext();
>>>>>>> int main() {
>>>>>>> gettext()
>>>>>>> ; return 0; }
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
> - the wisdom of Tarzan
