[GRASS-dev] [GRASS-PSC] too many branches => retirement GRASS6.5.svn (=develbranch6)
Helmut Kudrnovsky
hellik at web.de
Mon Apr 7 15:07:24 PDT 2014
Markus Metz-3 wrote
> Since the code base of devbr6 and relbr6 is largely identical,
> the same fix can be applied to both branches which is not a lot of
> work.
> grass-psc mailing list
> grass-psc at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-psc
are you sure devbr6 and relbr6 are largely identical?
if yes what's the benefit (for users and devs) to have both, when the focus
on grass7 development/improvement would be a desired target ?
if no what should be ported (from users' and devs'-view) from devbr6 to
relbr6, when the focus on grass7 development/improvement would be a desired
target ?
as Martin mentioned on the ML, there aren't anymore nightly devbr6-wingrass
nightlies (osgeo4w/standalone).
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-GRASS-PSC-too-many-branches-retirement-GRASS6-5-svn-develbranch6-tp5133400p5133712.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
