[GRASS-dev] [GRASS GIS] #1343: v.buffer2: difference between Linux 32bit and 64bit
GRASS GIS trac at osgeo.org
Tue Apr 8 23:30:56 PDT 2014
  Reporter:  mmetz    |       Owner:  grass-dev@…
      Type:  defect   |      Status:  reopened
  Priority:  normal   |   Milestone:  7.0.0
 Component:  Default  |     Version:  svn-develbranch6
Resolution:           |    Keywords:  v.buffer, v.buffer2
  Platform:  Linux    |         Cpu:  x86-64
Changes (by mmetz):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Reopening because v.buffer works only in GRASS7 and only if it uses the
 GEOS algorithm. A backport to GRASS6 is possible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1343#comment:2>
