[GRASS-dev] Handling of Python scripts on MS Windows
Martin Landa
landa.martin at gmail.com
Mon Apr 14 01:15:20 PDT 2014
2014-04-14 9:53 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
> There is quite a large margin between creating a monolithic application with
> everything bundled and leaving the user alone...
> To answer Martin's call for concrete action: how difficult would it be for
> you, Helmut, to create a GRASS installer without Python, so that we can test
> that scenario ? I don't have the Windows build toolchain set up at the
> moment, but if it's more work for you than a few lines of code to change and
> command to create a new package, then I'll try to find the time to do that.
I simply miss a reason. I would say that it will be more than one line
to change. Good luck if you want to spend energy/time on that. Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
