[GRASS-dev] [GRASS GIS] #1775: v.surf.rst does not respect mask
GRASS GIS trac at osgeo.org
Tue Apr 15 03:20:46 PDT 2014
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:  v.surf.rst   |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by neteler):
 See also trac #1718 for "ERROR: Input window changed while maps are open
 for read".
 See also r47601 for related fixed in i.topo.corr: Essentially replace
 G_get_set_window(&window);  --> Rast_get_window(&window);
 From ML: Rast_set_window() should be called before the map is opened.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:9>
