[GRASS-dev] [GRASS GIS] #718: r.li forgets mask/illegal filename
GRASS GIS trac at osgeo.org
Wed Apr 16 03:52:40 PDT 2014
  Reporter:  kyngchaos  |       Owner:  grass-dev@…
      Type:  defect     |      Status:  closed
  Priority:  major      |   Milestone:  6.4.4
 Component:  Raster     |     Version:  svn-releasebranch64
Resolution:  fixed      |    Keywords:  r.li, smp
  Platform:  All        |         Cpu:  All
Changes (by neteler):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:30 mmetz]:
 > Replying to [comment:29 neteler]:
 > > I retested it with current 6.4.svn:
 > g.region rast=lsat7_2002_40 -p
 > mkdir -p $HOME/.r.li/history/
 > echo "SAMPLINGFRAME 0|0|1|1
 > SAMPLEAREA 0.0|0.0|1.0|1.0" > $HOME/.r.li/history/landsat_test
 > r.li.shannon map=lsat7_2002_40 conf=landsat_test out=landsat_shannon
 > r.univar landsat_shannon
 > ERROR: Raster map <landsat_shannon> not found
 > > ... no output is produced by r.li.shannon.
 > With this configuration, the output is a text file. The
 > r.li daemon should have printed a corresponding message with
 > the path to the output file.
 It now does in the backported, corrected version:
 Result written to ASCII file </home/neteler/.r.li/output/landsat_shannon>
 The original issue reported here should also be fixed in the new version.
 Closing, feel free top reopen if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/718#comment:31>
