[GRASS-dev] [GRASS GIS] #2138: winGRASS6.4.svn - addon python script status?
trac at osgeo.org
Fri Apr 18 00:53:37 PDT 2014
Reporter: hellik | Owner: martinl
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.4
Component: Addons | Version: svn-releasebranch64
Resolution: | Keywords: wingrass, addon, python
Platform: MSWindows 7 | Cpu: x86-64
Changes (by hellik):
* status: closed => reopened
* resolution: fixed =>
Comment:
Replying to [comment:20 hellik]:
> Replying to [comment:18 hellik]:
> > for the record I've closed #1768 as duplication of #1768. will close
this ticket after testing the upcoming nightly.
> tested with
> (Fri Apr 18 09:37:14 2014) Befehl ausgeführt (2 Sek)
> System Info
> GRASS Version: 6.4.4svn
> GRASS SVN Revision: 59777
> GDAL/OGR: 1.10.1
> PROJ4: Rel. 4.8.0, 6 March 2012
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
> the content of the related bat-file
> @"%GRASS_PYTHON%" "%GRASS_ADDON_PATH%/r.basin.py" %*
> closing ticket
e.g. r.basin start by typing r.basin in the wxgui-commandline, then enter
all parameters und press the start button in the
r.basin-wxgui:
r.basin.py --verbose map=elevation at PERMANENT prefix=l
easting=636654.791181 northing=218824.126649 threshold=20
C:\OSGeo4W\bin\python.exe: can't open file 'r.basin.py':
[Errno 2] No such file or directory
but without the the py-extension, the addon script starts
r.basin --verbose map=elevation at PERMANENT prefix=l easting=636654.791181
ABSCHNITT 1a (von 4): Initiiere den Speicher.
ABSCHNITT 1b (of 4): Ermittle den Fluß aus der Karte heraus.
ABSCHNITT 2: A * Suche.
any idea?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:21>
