[GRASS-dev] i.spectral limited to 400 files
Yann Chemin
ychemin at gmail.com
Fri Apr 18 03:26:03 PDT 2014
In Ubuntu, I could expand the number of opened files by:
#PCA will require the extension of ulimit for open files in Ubuntu
sudo vi /etc/security/limits.conf
#There you should enter:
#username hard nofile 65000
#username soft nofile 10000
#before # End of file
and reboot
On 18/04/2014, Nikos Alexandris <nik at nikosalexandris.net> wrote:
> Yann Chemin wrote:
>> >> is there a way to modify i.spectral to remove the limit of 400 files:
> Glynn:
>> > The limit is from r.what. It probably wouldn't be that hard to fix.
> Markus N:
>> ... "nice to have" for sure.
>> BTW:
>> The next limit would be the operating system. Default Linux allows
>> 1024 files to be opened, which can be increased in
> Aren't there, however, any important side-effects in altering this limit?
> There must be a (security?) reason for the number 2^10.
> Nikos
