[GRASS-dev] [GRASS GIS] #2255: g.mlist warnings for layers found in other mapsets
GRASS GIS trac at osgeo.org
Fri Apr 18 04:09:26 PDT 2014
 Reporter:  pvanbosgeo   |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Default      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by neteler):
 Not sure what the issue is... here an example:
 grass71 -c ~/grassdata/nc_spm_08_grass7/user2
 GRASS 7.1.svn (nc_spm_08_grass7):~ > g.mlist rast
 raster map(s) available in mapset <PERMANENT>:
 aspect
 basin_50K
 elev_state_500m
 elevation
 elevation_shade
 zipcodes
 zipcodes_dbl
 # now copy over "elevation" map as found in search path to
 # current mapset:
 GRASS 7.1.svn (nc_spm_08_grass7):~ > g.copy rast=elevation,elevation
 Copy raster <elevation at PERMANENT> to current mapset as <elevation>
 # list again:
 raster map(s) available in mapset <user2>:
 WARNING: 'cell/elevation' was found in more mapsets (also found in
          <PERMANENT>)
 WARNING: Using <elevation at user2>
 elevation
 aspect
 basin_50K
 boundary_county_500m
 elev_state_500m
          <PERMANENT>)
 elevation_shade
 facility
 zipcodes_dbl
 GRASS 7.1.svn (nc_spm_08_grass7):~ > g.mapsets -l
 Available mapsets:
 PERMANENT landsat neteler user1 user2
 GRASS 7.1.svn (nc_spm_08_grass7):~ > g.mapsets -p
 Accessible mapsets:
 user2 PERMANENT
 So it tells the user that the map "elevation" exists multiple times in
 the search path ("Accessible mapsets")... Guess that's how it should be.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2255#comment:1>
