[GRASS-dev] GUI code dest dir
Vaclav Petras wenzeslaus at gmail.com
Fri Apr 18 08:50:20 PDT 2014
On Fri, Apr 18, 2014 at 10:44 AM, Martin Landa <landa.martin at gmail.com>wrote:
> > The same layout for src and dist would be good for editing because then
> > editors, python and other tools can just use the layout in src and it
> will
> > work. This would mean that things which are now in `lib/python` should
> go to
> > something which is named `grass` so that I can do
> So if you agree I will start with
> 1) etc/gui -> gui
> 2) etc/python -> lib/python
I'm still not sure what is the right solution for import problems. Now I
really cannot do all the tests but it would be better to it before 2). I
think you should be able to run Python libraries and modules when you set
PYTHONHOME to some directory in source code. From quick look it seems that
`lib/python` in src should be moved to `lib/python/grass` but than grass
would be the only directory in `lib/python`.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140418/fb407c12/attachment.html>
