[GRASS-dev] [GRASS GIS] #1718: r.resamp.rst broken in GRASS 7
GRASS GIS trac at osgeo.org
Sun Apr 20 10:25:51 PDT 2014
  Reporter:  rsbivand  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  7.0.0
 Component:  Raster    |     Version:  svn-releasebranch70
Resolution:  fixed     |    Keywords:  r.resamp.rst
  Platform:  All       |         Cpu:  Unspecified
Changes (by neteler):
  * status:  new => closed
  * version:  svn-trunk => svn-releasebranch70
  * resolution:  => fixed
Comment:
 Tested successfully in current 7.0.svn:
 GRASS 7.0.0svn (spearfish60_grass7):~ > g.region rast=elevation.dem
 GRASS 7.0.0svn (spearfish60_grass7):~ > r.univar elevation.dem -g
 n=292317
 null_cells=2661
 cells=294978
 min=1066
 max=1840
 range=774
 mean=1353.66931789804
 mean_of_abs=1353.66931789804
 stddev=177.040679835105
 variance=31343.402316476
 coeff_var=13.0785766874004
 sum=395700554
 GRASS 7.0.0svn (spearfish60_grass7):~ > r.resamp.rst --overwrite --verbose
 input=elevation.dem at PERMANENT ew_res=15 ns_res=15 elev=elev15
 Processing all selected output files will require
 4.50 MB of disk space for temp files.
 Temporarily changing the region to desired resolution ...
 Changing back to the original region ...
 Percent complete:
  100%
 dnorm in ressegm after grid before out2= 388.844442
 dnorm in mainc after grid before out1= 388.844442
 dnorm in mainc after grid before out2= 388.844442
 Temporarily changing the region to desired resolution...
 Changing the region back to initial...
 r.resamp.rst complete.
 GRASS 7.0.0svn (spearfish60_grass7):~ > r.univar elev15 -g
 n=1179912
 null_cells=0
 cells=1179912
 min=1066.04113769531
 max=1840.59228515625
 range=774.551147460938
 mean=1353.60878808034
 mean_of_abs=1353.60878808034
 stddev=177.077330758482
 variance=31356.3810685488
 coeff_var=13.0818691720825
 sum=1597139252.36145
 Closing as fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1718#comment:5>
