[GRASS-dev] [GRASS GIS] #2259: some temporal modules have empty manual page
trac at osgeo.org
Tue Apr 22 11:37:10 PDT 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Docs | Version: svn-trunk
Keywords: temporal | Platform: Unspecified
Cpu: Unspecified |
Description changed by martinl:
Old description:
> List of temporal modules with empty manual page:
> * t.rast.out.vtk
> * t.rast.to.rast3
> * t.rast3d.extract
> * t.rast3d.list
> * t.rast3d.mapcalc
> * t.rast3d.univar
> * t.remove
> * t.sample
> * t.support
> * t.topology
> * t.unregister
> * t.vect.db.select
> * t.vect.export
> * t.vect.extract
> * t.vect.import
> * t.vect.list
> * t.vect.observe.strds
> * t.vect.univar
> * t.vect.what.strds
> At least minimum info (description, example) should be added before
> releasing GRASS7.
New description:
* t.rast.out.vtk
* t.rast.to.rast3
* t.rast3d.extract
* t.rast3d.list
* t.rast3d.mapcalc
* t.rast3d.univar
* t.remove
* t.sample
* t.support
* t.topology
* t.unregister
* t.vect.db.select
* t.vect.export
* t.vect.extract
* t.vect.import
* t.vect.list
* t.vect.univar
* t.vect.what.strds
releasing GRASS7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2259#comment:1>
