[GRASS-dev] [GRASS GIS] #2258: t.create creates DB always in the PERMANENT
trac at osgeo.org
Tue Apr 22 14:02:53 PDT 2014
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Temporal | Version: unspecified
Keywords: t.register | Platform: Unspecified
Cpu: Unspecified |
Comment(by huhabla):
There is a reason why the temporal database is generated and used by
default in the PERMANENT directory. This will assure that by default all
maps from different mapsets are registered in the same temporal database.
A single temporal database can handle maps from different mapsets, it is
designed to handle maps from different mapsets. Consider the temporal
database as a location specific, mapset independent storage of temporal
information. The temporal framework makes sure that you can not modify
space time datasets or time stamps of maps "located" in other mapsets.
You can use t.connect to use a different temporal database (a path for
sqlite, connection string for postgresql). Hence you can force that the
current mapset will be used to store time stamped maps and space time
datasets by running t.connect in the new mapset. Be aware that the
connection information is stored mapset specific.
However, using mapset specific temporal databases has the drawback that
temporal information from other mapsets (STDS, time stamped maps) will not
be available. The reason is that sqlite does not support the merging of
different database files at runtime.
About temporal database creation: Each temporal command checks if a
temporal database exists, if there is no temporal database then a new one
will be created using the default settings (PERMANENT mapset) or the
mapset specific settings set by t.connect. Hence if you modify the
database connection at runtime with t.connect, the new temporal database
will be used, or created if not present, when a temporal command gets
invoked (except t.connect).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2258#comment:3>
