[GRASS-dev] [GRASS GIS] #2223: v.buffer flags -s and -c not	working(?)
    trac at osgeo.org
    Wed Apr 23 01:34:22 PDT 2014
 Reporter:  jbrauner     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  critical     |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:  v.buffer     |    Platform:  All
      Cpu:  Unspecified  |
Comment(by jbrauner):
 Replying to [comment:1 neteler]:
 > To my knowledge v.buffer only works properly when compiled with GEOS
 support.
 Isn't at least winGRASS (sorry my Linux box is broken at the moment)
 compiled with GEOS support? As far as I can conclude from the build
 information (see below) and the extended list of available operators for
 v.select it seems very likely to me. Sorry if this is an unqualified
 comment :)
 Cheers,
 Johannes
 g.version -bre
 GRASS 7.1.svn (2014)
  ./configure [... snip ...] --with-
 geos=/c/osgeo4w/usr/src/grass_trunk/mswindows/osgeo4w/geos-config [...
 snip ...]
 libgis Revision: 59317
 libgis Date: 2014-03-24 20:38:32 +0100 (po, 24 III 2014)
 PROJ.4: 4.8.0
 GDAL/OGR: 1.10.1
 GEOS: 3.4.2
 SQLite: 3.7.17
Ticket URL: <http://trac.osgeo.org/grass/ticket/2223#comment:3>
