[GRASS-dev] [GRASS GIS] #2262: t.create fails when mapset name	contains a dash
    trac at osgeo.org
    Wed Apr 23 10:35:56 PDT 2014
 Reporter:  martinl           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Temporal          |     Version:  svn-trunk
 Keywords:  t.create, mapset  |    Platform:  Unspecified
      Cpu:  Unspecified       |
 Steps to reproduce:
 g.mapset -c mapset-test
 t.connect database=/opt/grassdata/nc_spm_08_grass7/mapset-
 test/tgis/sqlite.db
 t.create output=test title="test" desc="test"
 CREATE TABLE  test_mapset-test_raster_register (
   id VARCHAR NOT NULL, -- This colum is a primary key storing the
 registered raster map.ids
   PRIMARY KEY (id)
 CREATE INDEX test_mapset-test_raster_register_index ON test_mapset-
 test_raster_register (id);INSERT INTO strds_base ( name  ,creator  ,mapset
 ,creation_time  ,modification_time  ,temporal_type  ,id  ,semantic_type )
 VALUES ('test' ,'landa' ,'mapset-test' ,'2014-04-23 19:35:19.818196'
 ,'2014-04-23 19:35:19.818210' ,'absolute' ,'test at mapset-test' ,'mean') ;
 INSERT INTO strds_absolute_time ( start_time  ,granularity  ,id  ,map_time
 ,end_time ) VALUES (NULL ,NULL ,'test at mapset-test' ,NULL ,NULL) ;
 INSERT INTO strds_spatial_extent ( north  ,bottom  ,west  ,top  ,proj
 ,east  ,id  ,south ) VALUES (NULL ,NULL ,NULL ,NULL ,'XY' ,NULL ,'test
 @mapset-test' ,NULL) ;
 INSERT INTO strds_metadata ( max_min  ,description  ,ewres_min  ,title
 ,min_max  ,nsres_min  ,nsres_max  ,number_of_maps  ,raster_register
 ,command  ,min_min  ,ewres_max  ,id  ,max_max  ,aggregation_type ) VALUES
 (NULL ,'test' ,NULL ,'test' ,NULL ,NULL ,NULL ,NULL ,'test_mapset-
 test_raster_register' ,'# 2014-04-23 19:35:19
 t.create output="test" title="test" desc="test"
 ' ,NULL ,NULL ,'test at mapset-test' ,NULL ,NULL) ;
   File "/opt/src/grass_trunk/dist.x86_64-unknown-linux-
 gnu/scripts/t.create", line 83, in <module>
     main()
 gnu/scripts/t.create", line 79, in main
     semantic, None, grass.overwrite())
 gnu/etc/python/grass/temporal/open_stds.py", line 169, in
 open_new_space_time_dataset
     sp.insert(dbif)
 gnu/etc/python/grass/temporal/abstract_space_time_dataset.py", line 367,
 in insert
     dbif.execute_transaction(statement)
 gnu/etc/python/grass/temporal/core.py", line 955, in execute_transaction
     self.cursor.executescript(statement)
 sqlite3.OperationalError: near "-": syntax error
Ticket URL: <http://trac.osgeo.org/grass/ticket/2262>
