[GRASS-dev] [GRASS GIS] #2258: t.create creates DB always in the PERMANENT
trac at osgeo.org
Thu Apr 24 19:55:57 PDT 2014
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Temporal | Version: unspecified
Keywords: t.register | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:5 huhabla]:
> > Does it handle race conditions, i.e. where two users both try to
create the database at the same time?
> No. How does GRASS handle the race condition in case two user try to
create a mapset with the same name at the same time?
One of the mkdir() calls will fail, and G_make_mapset() will return -1 to
its caller.
This is correct behaviour for creating a new mapset, which is supposed to
"belong" to the user creating it. Creating a mapset should be a distinct
operation from using an existing mapset. If a mapset with that name
already exists, creation should fail; a "create" operation shouldn't just
use an existing mapset (typically, incorrect ownership will prevent this).
This wouldn't be correct behaviour for creating a shared database, where
the desired semantics are "use it if it exists, otherwise create it". In
the event of a race condition, the process should either create the
database (if it won the race) or use the existing database (if it lost the
race). In neither case should it fail.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2258#comment:6>
