[GRASS-dev] Handling of Python scripts on MS Windows
Thu Apr 24 20:18:09 PDT 2014
Martin Landa wrote:
> It's easier to check if the file is a python script and if so than
> to force to use bundled version of Python.
So long as I have commit access, GRASS isn't going to be "forcing" the
use of a non-system Python.
By all means provide fall-backs, workarounds, alternatives, or
whatever, but anything which tries to make such things mandatory is
going to get reverted. Again.
Batch files aren't a problem, as they can just be deleted or the
directory removed from PATH.
