[GRASS-dev] [GRASS GIS] #560: WinGRASS not deleting temp ppm files from map display
trac at osgeo.org
Fri Apr 25 23:56:56 PDT 2014
Reporter: isaacullah | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.4
Component: Display | Version: 6.4.0 RCs
Keywords: v.digit, ppm, temp, wingrass | Platform: MSWindows XP
Cpu: x86-32 |
Changes (by hamish):
* keywords: v.digit ppm temp, wingrass => v.digit, ppm, temp, wingrass
Comment:
> Should this go into 6.4.svn or 7.0.x?
yes, it should go into 6.4.svn at some point.
I'm not sure what I meant by "more [cleanup] proposed for trunk", but of
course some solution is needed there too if it sees the same bug. someone
running windows should be able to check if their `C:\Documents and
Settings\$USER\Local Settings\Temp` (or similar) is full of old grass .ppm
files.
looking at r56444 I'm reminded about this: "FIXME: the second RunCommand()
here locks up the GUI, need to use 'xkill' to recover."
which makes cairo unusable from the wxGUI on Grass 6.x (!). (#943)
but that's another matter (help required by process-signals-on-Windows
expert).
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/560#comment:29>
