[GRASS-dev] pygrass documentation
Markus Neteler
neteler at osgeo.org
Sun Apr 27 14:35:14 PDT 2014
(back to list)
On Sun, Apr 27, 2014 at 11:18 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Sun, Apr 27, 2014 at 4:57 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> it works on my Fedora 20 box.
>> Just Debian does not behave.
>> > Are you sure you are in a GRASS session?
>> Sure, thanks to
>> https://trac.osgeo.org/grass/changeset/59947
> In this case, it is possible that the problem is the same as the one with
> toolboxes and few other things, the session might not be properly
> established. Have you tried be in GRASS and then do make? This helps in the
> case of toolboxes on Mac.
Indeed, inside a GRASS session it also works on the Debian server (not
needed on Fedora thanks to r59947).
So the bug must be somewhere in
include/Make/Rules.make
--> run_grass
Likely some silly path issue.
Markus
