[GRASS-dev] Handling of Python scripts on MS Windows
Helmut Kudrnovsky
hellik at web.de
Mon Apr 28 12:32:40 PDT 2014
Hamish wrote:
>I think that's more a reflection on the way things are done in the MS
>Windows world: the last program to install itself wins.
yes
>Which leads to
>the usual 1st trouble shooting step on Windows after seeing if a
>rebooting helps: try uninstalling then reinstalling the program. Then
>the program you are trying to use becomes the last thing to be installed
>and magically wins again (but by breaking the previously installed
>conflicting software).
a not unusal way of fixing things ;-)
Moritz Lennert wrote
> On 27/04/14 22:52, Markus Metz wrote:
>> I do not understand this ongoing discussion on WinGRASS7+Python. My
>> proposed solution caters for all possibilities, in particular:
>> - an existing incompatible .py file assocation
>> [add your workaround here]
>> - changes in any existing .py file association after GRASS has been
>> installed
>> [add your check-at-startup-mechanism here]
> I think we just have to agree to disagree on this at this stage, and
> implement a solution that if not satisfying everyone, at least does not
> dissatisfy anyone more than necessary.
> From the current discussion I take that the .bat file solution is one
> that will satisfy those who want GRASS to "just work" on MS Windows
> without putting any burden on the user. In order to not dissatisfy those
> who do not want GRASS to impose a specific version of Python, it should
> be easy to "switch" off the .bat file solution, i.e. by simply resetting
> PATH and/or erasing the directory with the .bat files.
> Can everyone agree on that solution (not meaning that you consider it
> the best solution, but that you can live with it) ?
regarding "who do not want GRASS to impose a specific version of Python",
have a look at:
http://trac.osgeo.org/grass/browser/grass/trunk/REQUIREMENTS.html
- Python >= 2.6 (for temporal framework, scripts, wxGUI, and ctypes
interface)
Note: Python 3 support is still in development
- wxPython >= 2.8.10.1 (for wxGUI)
- NumPy >= 1.0.4 (for various wxGUI components and pyGRASS)
- Python dateutil Library ("python-dateutil", needed for the tgrass modules
t.*)
- Python Imaging Library or PILLOW (highly recommended for wxGUI and
necessary for wxGUI Cartographic Composer)
so there are basically some kind of "minimum version of python and python
package" requirements; this has to be communicated in a clear way to users
"who do not want GRASS to impose a specific version of Python".
regarding "switch" off the .bat file solution, there may be some more work
than just resetting PATH and erasing bat files.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Handling-of-Python-scripts-on-MS-Windows-tp5081335p5137614.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
