[GRASS-dev] [GRASS GIS] #2385: v.in.ogr doesn't use information from dblogin file about external PostgreSQL server
trac at osgeo.org
Fri Aug 1 01:04:18 PDT 2014
PostgreSQL server
Reporter: hemeybo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Database | Version: svn-releasebranch70
Keywords: v.in.ogr PostgreSQL db.login db.databases | Platform: Linux
Cpu: x86-64 |
Comment(by hemeybo):
Unfortunately, there is not much improvement. The error moved on from
"Unable to list databases" to "Unable to open data source" with the
correct connection details. Here the new error message:
v.in.ogr dsn=PG: layer=bfn.nw_buk1000 output=nw_buk1001
ERROR 1: PQconnectdb failed.
could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
ERROR: Unable to open data source
<PG:dbname=host=134.110.32.101,dbname=gis>
It seems like the dsn is not created properly - the first "dbname=" is
wrong, in my opinion.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2385#comment:2>
