[GRASS-dev] GRASS 7.0 beta3 problems on Mac
Anna Petrášová
kratochanna at gmail.com
Mon Aug 11 13:26:18 PDT 2014
On Mon, Aug 11, 2014 at 3:24 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> I just tried to compile GRASS 7.0 beta 3 for release and it appears to be
> broken. It worked fine 15 July. Here are the problems.
> 1st, there is a set of GUI errors that pop up from make. These were
> present awhile back but ‘bogus’ in that they did not seem to affect running
> (though I suspected that they were related to other issues that caused
> compiling problem). These went away and all was well by the mid-July build.
> But they are back again. I hoped that they were again ‘bogus’ but the GUI
> won’t launch now.
> Here are the errors on launch:
> ======================= launch errors ================
> GRASS 7.0.0svn (nc_spm_08):~ > Traceback (most recent call last):
> File
> "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py",
> line 138, in <module>
> sys.exit(main())
> File
> line 131, in main
> app = GMApp(workspaceFile)
> File
> line 45, in __init__
> wx.App.__init__(self, False)
> File
> "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py",
> line 7981, in __init__
> self._BootstrapApp()
> File
> line 7555, in _BootstrapApp
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> File
> line 79, in OnInit
> workspace = self.workspaceFile)
> File
> "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
> line 118, in __init__
> self._menuTreeBuilder = LayerManagerMenuData()
> File
> "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py",
> line 40, in __init__
> MenuTreeModelBuilder.__init__(self, filename,
> expandAddons=expandAddons)
> File
> "/Users/cmbarton/grass_source/grass7_rb/macosx/dist/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/menutree.py",
> line 64, in __init__
> xmlTree = etree.parse(filename)
> File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
> line 1182, in parse
> tree.parse(source, parser)
> File
> line 657, in parse
> self._root = parser.close()
> File
> line 1654, in close
> self._raiseerror(v)
> File
> line 1506, in _raiseerror
> raise err
> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
> This looks like the same error that I’d had to deal with earlier, but
> which appeared fixed by the mid-July build. I have a workaround but it is a
> PITA.
> The make errors are here. As before they all are related to a new
> windowing environment:
> ================== list of modules with make errors ===========
> Errors in:
> Errors in:
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/animation
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/mapswipe
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/gmodeler
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/rlisetup
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/psmap
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/dbmgr
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/vdigit
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/iclass
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/gcp
> /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/timeline
> Here is an example of the error in one of the above modules:
> cd /Users/cmbarton/grass_source/grass7_rb/gui/wxpython/animation
> cmb-imaccsdc:animation cmbarton$ make
> /Applications/Xcode.app/Contents/Developer/usr/bin/make
> /Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/docs/html/g.gui.animation.html
> GISRC=/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/demolocation/.grassrc70
> GISBASE=/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0
> PATH="/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/bin:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/bin:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/scripts:$PATH"
> PYTHONPATH="/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/etc/python:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/gui/wxpython:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/bin:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/scripts:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/lib:/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/lib:" LC_ALL=C
> /Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/scripts/g.gui.animation
> --html-description < /dev/null | grep -v '</body>\|</html>'
> > g.gui.animation.tmp.html
> File
> "/Users/cmbarton/grass_source/grass7_rb/dist.x86_64-apple-darwin13.3.0/scripts/g.gui.animation",
> line 55, in <module>
> import wx
> File
> "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/__init__.py",
> line 45, in <module>
> from wx._core import *
> File
> "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py",
> line 4, in <module>
> import _core_
> ImportError:
> /usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core_.so:
> no appropriate 64-bit architecture (see "man python" for running in 32-bit
> mode)
> make[1]: *** [g.gui.animation.tmp.html] Error 1
> rm g.gui.animation.tmp.html
> make: *** [guiscript] Error 2
This is apparently problem with mixing 32 and 64 bit architecture. Have you
changed something in you compiling environment? I will try to recompile
grass on Mac tomorrow, but I was compiling it recently and eventually I was
able to compile successfully (I had problems with mixed Python installation
on that computer).
Anna
> In fact I DO have this set up to compile and run Python in 32 bit mode.
> I’ve been doing this for a couple years while waiting for wxPython 64 bit
> to stabilize and mature (not there yet as of 2.9).
> This all worked a couple weeks ago, which makes this frustrating.
> I can try the new wxPython 3.0 but I have no idea whether it works with
> the current GRASS GUI.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140811/33d81244/attachment.html>
