[GRASS-dev] [GRASS GIS] #2391: font setting for map display broken on Mac
GRASS GIS trac at osgeo.org
Tue Aug 12 15:08:26 PDT 2014
 Reporter:  cmbarton   |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  7.0.0
Component:  wxGUI      |     Version:  unspecified
 Keywords:             |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
 The font setting dialog for map display in preferences does not work on
 the Mac. It displays an empty window rather than a list of fonts.
 The font setting dialog for command output works fine however. The widget
 used for command output fonts should also be used for map display fonts.
 This behavior is the same in GRASS 7.0 beta 3 and 7.1.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2391>
