[GRASS-dev] GRASS GIS 6.4.4 r.li modules
Martin Landa landa.martin at gmail.com
Wed Aug 13 02:04:35 PDT 2014
please fill ticket on Trac about that. Thanks, Martin
2014-08-13 10:58 GMT+02:00 Helmut Kudrnovsky <hellik at web.de>:
> Martin Landa wrote
>> Hi,
>> 2014-08-13 10:10 GMT+02:00 Helmut Kudrnovsky <
>> hellik@
>>> r.li.setup seems to be empty, see attached screenshot.
>>> <http://osgeo-org.1560.x6.nabble.com/file/n5156085/WinGrass645svncapture_13082014_100649.png>
>> I am getting the same dialog on Linux when launching the module from
>> menu. When launching the module from wxGUI command line I am getting
>> different dialog (Tcl/Tk configuration tool). Martin
>> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
>> grass-dev mailing list
>> grass-dev at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> now conf-file generated in winGRASS7.1svn and the conf file stored e.g.
> C:\Users\normal\AppData\Roaming\GRASS6\movwindow7
> some test:
> r.li.mps --verbose map=myforest at user1
> conf=C:\Users\normal\AppData\Roaming\GRASS6\movwindow7
> output=myforest_mean_patch_size
> ERROR: Cannot find configuration file
> <C:\Users\normal\.r.li\history\C:\Users\normal\AppData\Roaming\GRASS6\movwindow7>
> r.li.padrange --verbose map=myforest at user1
> output=myforest_padrange
> r.li.padsd --verbose map=myforest at user1
> conf=C:\Users\normal\AppData\Roaming\GRASS6\movwindow7 output=myforest_padsd
> although the path to the conf file is given, it seems it's hard coded where
> the r.li.*-module looks for the conf file (see doubling the path in the
> error message)
> manually creating the .r.li-folder where the module looks for and manually
> putting there the conf file, the r.li.*-module is working:
> conf=C:\Users\normal\.r.li\history\movwindow7 output=myforest_padsd
> r.li.padsd komplett. Raster map <myforest_padsd> created.
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-GIS-6-4-4-r-li-modules-tp5148344p5156099.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev at lists.osgeo.org
