[GRASS-dev] [GRASS GIS] #2392: GRASS GIS 6.4.5 svn r.li modules - issues with hard coded path to conf files
GRASS GIS trac at osgeo.org
Wed Aug 13 02:23:11 PDT 2014
files
 Reporter:  hellik    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  6.4.5
Component:  Raster    |     Version:  svn-releasebranch64
 Keywords:            |    Platform:  MSWindows 7
      Cpu:  x86-32    |
 from the ML
 http://lists.osgeo.org/pipermail/grass-dev/2014-August/070384.html
 now conf-file generated in winGRASS7.1svn and the conf file stored e.g.
 C:\Users\normal\AppData\Roaming\GRASS6\movwindow7
 some test:
 r.li.mps --verbose map=myforest at user1
 conf=C:\Users\normal\AppData\Roaming\GRASS6\movwindow7
 output=myforest_mean_patch_size
 ERROR: Cannot find configuration file
 <C:\Users\normal\.r.li\history\C:\Users\normal\AppData\Roaming\GRASS6\movwindow7>
 r.li.padrange --verbose map=myforest at user1
 output=myforest_padrange
 r.li.padsd --verbose map=myforest at user1
 output=myforest_padsd
 although the path to the conf file is given, it seems it's hard coded
 where
 the r.li.*-module looks for the conf file (see doubling the path in the
 error message)
 manually creating the .r.li-folder where the module looks for and manually
 putting there the conf file, the r.li.*-module is working:
 conf=C:\Users\normal\.r.li\history\movwindow7 output=myforest_padsd
 r.li.padsd komplett. Raster map <myforest_padsd> created.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392>
