[GRASS-dev] metadata naming and location
Matej Krejci matejkrejci at gmail.com
Thu Aug 14 04:49:52 PDT 2014
Hi Luca,
I didn't try metadata tool yet but, the metadat are created
> automatically by GRASS or the user have to create them?
> If the answer is the first one I fully agree with your proposal
> otherwise I'd leave the choice where save the metadata to the user...
Metadata are created only by user. In editor is option to set working
directory. By default is the directory path/to/location/mapset/metadata. After
click on save button user is asked by dialog window to selecting directory
in any case. So it meets with your suggestion :)
Thanks Matej
------------- dal�� ��st ---------------
HTML p��loha byla odstran�na...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140814/2b063a57/attachment.html>
