[GRASS-dev] [GRASS-SVN] r61619 - in grass-addons/grass7/gui/wxpython/wx.metadata: . g.gui.metadata
Vaclav Petras wenzeslaus at gmail.com
Thu Aug 14 07:23:41 PDT 2014
On Thu, Aug 14, 2014 at 8:58 AM, <svn_grass at osgeo.org> wrote:
> +sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc',
> 'wx.metadata'))
Do you this this is robust enough?
There is a function to do something like this. Does this one suite you?
I still think that the current solution is not good. We probably should
have the directory with packages on path and then import like this:
from wxmetadata.editor import MdMainEditor
when using the package by module, rather then current:
from editor import MdMainEditor
But I think this requires some changes in makefiles, directory layout and
naming convections and there is actually a ticket with similar topic.
http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py#L84
http://trac.osgeo.org/grass/changeset/58208
http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/pygrass/functions.py#L270
http://trac.osgeo.org/grass/ticket/2132
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140814/51bd5d6b/attachment-0001.html>
