[GRASS-dev] [GRASS GIS] #2105: Missing guidelines for testing
trac at osgeo.org
Thu Aug 14 10:58:49 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: task | Status: closed
Priority: normal | Milestone: 7.1.0
Component: Tests | Version: svn-trunk
Resolution: fixed | Keywords: testing, tests, PyUnit, doctest, testsuite
Platform: All | Cpu: Unspecified
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
* milestone: 7.0.0 => 7.1.0
Comment:
There was a GSoC:
* wiki:GSoC/2014/TestingFrameworkForGRASS
And documentation is now available:
* http://grass.osgeo.org/grass71/manuals/libpython/gunittest_testing.html
* source:grass/trunk/lib/python/docs/src/gunittest_testing.rst?rev=61572
This ticket was asking for documentation but new possible tool for testing
was discussed too, so here are the points from comment:7 applied to
current state of testing framework.
Python libraries Python:
* `gunittest`
* `unittest` use its assert methods through `gunittest`
* `doctest` use only for documentation purposes and then test this
documentation (i.e. do complex tests using `gunittest`), there is a
special way how to import tests
Functions in Python modules:
* doctest should at least partially work, currently best to invoke
directly (without testing framework)
* to standardize/promote `--test` parameter for GRASS modules might be
useful here
* others under investigation
Interface of C/C++ libraries:
* test using special (test) GRASS modules, invoke these separately for
benchmark and as standard GRASS modules through `gunittest`
* test as Python libraries through ctypes
Internal (static, private, ...) functions in C/C++ libraries:
* N/A
Functions in C/C++ modules:
* use special (test) GRASS modules as for C/C++ libraries
useful here
* static and private cannot be tested
C/C++ modules and Python modules:
* `gunittest`
There are five other main areas of the testing topic:
* recursive running of tests
* e.g., `python -m grass.gunittest.main --location nc_spm_grass7
--location-type nc`
* `make test` not implemented
* reports/outputs
* textual output on stdout
* HTML
* parsable key-value files with summaries
* XML or database not implemented
* automatic and online running supported using custom scripts and
documented for custom server
* tests currently runs every day
* no online testing services explicitly supported or tested
* supporting functionality especially that for comparing (maps, numbers)
implemented or using `unittest`
* data for testing is a complex issue but most important are random data,
data included in tests and NC SPM sample location, other can be used too
but this was not much tested yet
Closing this ticket as more then fixed, create new tickets for further
issues with testing (use component Tests).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2105#comment:9>
