[GRASS-dev] GRASS 7 add-ons on Mac OSX (10.9)
Johannes Radinger johannesradinger at gmail.com
Fri Aug 15 08:07:09 PDT 2014
I try to install add-ons on GRASS GIS 7 beta on Mac OSX (10.9).
G7 has been installed including all frameworks from
http://grassmac.wikidot.com/downloads
(snapshot from 11.08.2014, GRASS 7.0.0svn (r61585M)).
Now I'd like to install add-ons but neither the g.extension gui
nor running g.extension via command line works (tested with
2-3 extensions)
1) via GUI:
g.extension --verbose extension=r.fuzzy.system svnurl=
http://svn.osgeo.org/grass/grass-addons/grass7
Fetching <r.fuzzy.system> from GRASS-Addons SVN (be patient)...
A    r.fuzzy.system/flood.map
A    r.fuzzy.system/helpers.c
A    r.fuzzy.system/local_proto.h
A    r.fuzzy.system/flood.rul
A    r.fuzzy.system/rule_parser.c
A    r.fuzzy.system/main.c
A    r.fuzzy.system/system.c
A    r.fuzzy.system/f_result.png
A    r.fuzzy.system/fuzzylogic.c
A    r.fuzzy.system/io.c
A    r.fuzzy.system/map_parser.c
A    r.fuzzy.system/Makefile
A    r.fuzzy.system/r.fuzzy.system.html
 U   r.fuzzy.system
Checked out revision 61649.
Compiling...
mkdir -p
/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin
mkdir -p
/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/etc/r.fuzzy.system
mkdir -p
/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/docs/html
mkdir -p
/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/docs/man/man1
test -d OBJ.x86_64-apple-darwin13.3.0 || mkdir -p
gcc -I/usr/local/include -g -O2   -arch i386 -arch x86_64
-I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include
 -DPACKAGE=\""grassmods"\"
-I/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/include -o
OBJ.x86_64-apple-darwin13.3.0/fuzzylogic.o -c fuzzylogic.c
OBJ.x86_64-apple-darwin13.3.0/helpers.o -c helpers.c
OBJ.x86_64-apple-darwin13.3.0/io.o -c io.c
OBJ.x86_64-apple-darwin13.3.0/main.o -c main.c
OBJ.x86_64-apple-darwin13.3.0/map_parser.o -c map_parser.c
OBJ.x86_64-apple-darwin13.3.0/rule_parser.o -c rule_parser.c
OBJ.x86_64-apple-darwin13.3.0/system.o -c system.c
system.c:122:11: warning: 7 enumeration values not handled
in switch: 't_START', 't_IS_NOT', 't_IS'... [-Wswitch]
                switch (operator_stack[opr_top]) {
: && gcc -L/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib
-L/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib -arch i386 -arch
x86_64    -L/usr/local/lib   -o
/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin/r.fuzzy.system
OBJ.x86_64-apple-darwin13.3.0/helpers.o OBJ.x86_64-apple-darwin13.3.0/io.o
OBJ.x86_64-apple-darwin13.3.0/system.o    -lgrass_raster.7.0.0svn
-lgrass_gis.7.0.0svn
1 warning generated.
/bin/sh: Radinger-2668/gisrc: No such file or directory
make: *** [r.fuzzy.system.tmp.html] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
if [
"/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin/r.fuzzy.system"
!= "" ] ; then
GISRC=/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/grass7-Johannes
Radinger-2668/gisrc
GISBASE=/Applications/GRASS/GRASS-7.0.app/Contents/MacOS
PATH="/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts:$PATH"
PYTHONPATH="/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/python:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/gui/wxpython:$PYTHONPATH"
DYLD_LIBRARY_PATH="/var/folders/z6/kpf8b53j04vcgq71ycrqzs040000gq/T/tmptRWIEo/r.fuzzy.system/bin:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib:/Users/Johannes
Radinger/Library/GRASS/7.0/Modules/lib:/Library/GRASS/7.0/Modules/lib"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
r.fuzzy.system.tmp.html ; fi
rm r.fuzzy.system.tmp.html
2) command line:
GRASS 7.0.0svn (Test_XY):~ > g.extension extension=r.fuzzy.system
Compiling...
*system.c:122:11: **warning: **7 enumeration values not handled in switch:
't_START',*
*      't_IS_NOT', 't_IS'... [-Wswitch]*
't_START',*
FEHLER: Compilation failed, sorry. Please check above error messages.
For other add-ons I get also error messages. E.g. for r.fidimo (python
add-on)
I get:
GRASS 7.0.0svn (Test_XY):~ > g.extension extension=r.fidimo
Fetching <r.fidimo> from GRASS-Addons SVN (be patient)...
Compiling...
make: *** [r.fidimo.tmp.html] Error 1
Any suggestion. Do I need to install add-ons differently on a Mac, or
is this feature broken at the moment?
/Johannes
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140815/3526546c/attachment-0001.html>
