[GRASS-dev] [GRASS GIS] #2395: Startup runs as in Cygwin when CYGWIN is set although running as native application
GRASS GIS trac at osgeo.org
Wed Aug 20 01:29:53 PDT 2014
application
 Reporter:  wenzeslaus                                |       Owner:  grass-dev@…
     Type:  defect                                    |      Status:  new
 Priority:  normal                                    |   Milestone:  7.0.0
Component:  Startup                                   |     Version:  svn-releasebranch70
 Keywords:  cygwin, wingrass, environmetal variables  |    Platform:  MSWindows 8
      Cpu:  Unspecified                               |
Comment(by hellik):
 Replying to [comment:2 sindile]:
 > I have replaced etc\grass70.py with the attached grass.py (have renamed
 it to grass70.py) as per this email http://lists.osgeo.org/pipermail
 /grass-user/2014-August/070728.html
  in the attached script
 # Variables substituted during build process
 if 'GISBASE' in os.environ:
     gisbase = os.environ['GISBASE']
 else:
     gisbase = "@GISBASE@"
 cmd_name = "@START_UP@"
 grass_version = "@GRASS_VERSION_NUMBER@"
 ld_library_path_var = '@LD_LIBRARY_PATH_VAR@'
 if 'GRASS_PROJSHARE' in os.environ:
     config_projshare = os.environ['GRASS_PROJSHARE']
 else:
     config_projshare = "@CONFIG_PROJSHARE@"
 it should be something (adapted to beta3) like
 else:
     gisbase = "/c/OSGeo4W/apps/grass/grass-7.0.0svn"
 cmd_name = "grass70"
 grass_version = "7.0.0svn"
 ld_library_path_var = 'PATH'
 else:
     config_projshare = "/c/OSGeo4W/share/proj"
Ticket URL: <http://trac.osgeo.org/grass/ticket/2395#comment:3>
