[GRASS-dev] [GRASS GIS] #2398: grass.exec_command should add .exe where needed
trac at osgeo.org
Wed Aug 20 04:43:26 PDT 2014
Reporter: michikommader | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python | Version: svn-releasebranch70
Keywords: | Platform: MSWindows 7
Cpu: x86-32 |
Using the GUI or CMD-interface I get the following error when running
v.centroids:
v.centroids input=in output=out
File "C:\OSGeo4W\apps\grass\grass-7.0.0svn\scripts\v.centr
oids.py", line 69, in <module>
main()
oids.py", line 63, in main
grass.exec_command("v.category", type = 'area',
**options)
File "C:\OSGeo4W\apps\grass\grass-7.0.0svn\etc\python\gras
s\script\core.py", line 499, in exec_command
os.execvpe(prog, args, env)
Peeking into scripts/v.centroids.py at line 63 reveals a call to
grass.exec_command("v.category", type = 'area', **options)
which fixes the error when changed to
grass.exec_command("v.category.exe", type = 'area', **options)
It looks like you have to add a ".exe" in some cases under Windows.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2398>
