[GRASS-dev] [GRASS GIS] #2150: Cannot call Python scripts from Python on MS Windows
Vaclav Petras
wenzeslaus at gmail.com
Fri Aug 22 09:02:48 PDT 2014
Hi Martin, bat files could be handled by g.extension. See also ticket to
support compiling C modules on unix. (I cannot search it now.) Python
modules on MS Windows are in the same situation as C modules on unix. Vaclav
> Reporter: wenzeslaus | Owner: grass-dev@…
> Type: defect | Status: new
> Priority: blocker | Milestone: 7.0.0
> Component: Python | Version:
> svn-releasebranch64
> Keywords: packaging, MAXREPEAT, scripts | Platform: MSWindows 7
> Cpu: Unspecified |
> Comment(by martinl):
> Replying to [comment:8 glynn]:
> > > My opinion is that requiring BAT file for Python scripts is much more
> worse solution that r57910.
> > Also, note that there's nothing special about .bat (or .cmd). The
> mechanism used for "executing" anything other than binary executables is
> the same, whether it's .bat or .py. If .bat works when .py doesn't, that
> indicates a fault in the Python installation.
> Update: as a result of never ending discussion I took liberty to add
> generation of bat files in r61136. The missing part is how to solve user
> python scripts.
> Ticket URL: <http://trac.osgeo.org/grass/ticket/2150#comment:10>
> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140822/638cfa0d/attachment.html>
