[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Tue Dec 2 14:30:33 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:81 hcho]:
> I don't think it's a good idea to have to type an underscore before
certain option names in Python or possibly other languages and we could
avoid such annoying/inconsistent situations by naming elements more
carefully.
There are two reasons why an option name cannot be used in Python. One is
if it doesn't conform to the syntax for an identifier (e.g. starts with a
digit). The other is if it is a reserved word (e.g. "from").
Avoiding the first case is simple enough. A requirement that option names
begin with a letter and consist solely of letters, digits and underscores
will ensure conformance with the identifier syntax for any common
language.
The second one is more awkward, as different languages have different sets
of reserved words. The only real constant is that many of them are quite
common words which would frequently be an ideal choice for an option name.
I'm not sure that we should reject such names simply because they can't be
used as a variable/parameter/etc name in a specific language without a
tweak such as adding an underscore (or changing case; now that option
names are limited to lower-case, having grass.script.make_command() force
each name to lower case would be feasible).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:83>
