[GRASS-dev] [GRASS GIS] #2503: wxdigit: wrong undo & redo
GRASS GIS trac at osgeo.org
Wed Dec 3 10:00:34 PST 2014
 Reporter:  mlennert     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  digitizer    |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mlennert):
 Replying to [comment:7 mmetz]:
 > Replying to [comment:6 mlennert]:
 > > There is still one issue I've come upon: when features are
 automatically modified from the form they are digitized in because of
 overlaps, the second original feature causing the overlap seems to be
 erased from the undo stack, meaning that it remains, even if you undo all
 the way to origin or if you close without saving.
 > > To reproduce, digitize a line and then a second line that crosses that
 line. The lines are correctly split at the intersection. If you then undo
 the second line remains in its original (unsplit) form. The same is true
 for two overlapping polygons or a line crossing a polygon.
 > The list of updated lines as returned by the vector lib was incomplete.
 Fixed in r63349,50 (trunk, relbr70), please test.
 Still not quite:
 [http://tomahawk.ulb.ac.be/moritz/wxdigit_undo_redo4.ogv].
 If you need more explanation, I can write some, but right now I have to
 go.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2503#comment:8>
