[GRASS-dev] [GRASS GIS] #2503: wxdigit: wrong undo & redo
GRASS GIS trac at osgeo.org
Sat Dec 6 13:14:27 PST 2014
  Reporter:  mlennert     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  digitizer
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by mmetz):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:11 mmetz]:
 > Replying to [comment:10 mlennert]:
 > > Replying to [comment:9 mmetz]:
 > > > Replying to [comment:8 mlennert]:
 > > > > Replying to [comment:7 mmetz]:
 > > > > > The list of updated lines as returned by the vector lib was
 incomplete. Fixed in r63349,50 (trunk, relbr70), please test.
 > > > > Still not quite:
 [http://tomahawk.ulb.ac.be/moritz/wxdigit_undo_redo4.ogv].
 > > > > If you need more explanation, I can write some, but right now I
 have to go.
 > > > Got it. This bug (yet another one) should be fixed in r63364,5
 (trunk only).
 > > Wow, great detective work there ! As of now I haven't been able to
 find any other bugs linked to undo/redo. This fix should be backported to
 grass7release and then I think we can close this bug for now.
 > I do not fully understand 1) why the fix is needed, 2) why the fix is
 working.
 The fix is working because V2_rewrite_line_nat() does not work as
 expected, it does not rewrite, it always deletes the line and writes out a
 new line (COW). All fixes related to this ticket have been backported to
 relbr70 in r63397,8 after testing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2503#comment:12>
