[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Ivan Minčík
ivan.mincik at gmail.com
Sun Dec 7 22:16:07 PST 2014
Hi all,
I did small investigation why Ubuntu package of GRASS 7 is failing to build
on Launchpad.
The problem is caused by building single page documentation (make
htmldocs-single). This make command is also failing on my computer.
Building multi-page documentation (make htmldocs) is running without
problem.
I am not able to figure out the problem with 'single-page' build, since I
do not use Doxygen at all.
So the question is if somebody is able to fix 'htmldocs-single' or it is
possible at least temporary substitute 'htmldocs-single' to 'htmldocs' to
allow building the package.
Ivan Minčík
ivan.mincik at gmail.com GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141208/abd8fec0/attachment.html>
