[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Ivan Mincik
ivan.mincik at gmail.com
Mon Dec 8 02:34:05 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 08.12.2014 10:57, Martin Landa wrote:
> Hi Ivan,
> 2014-12-08 10:26 GMT+01:00 Ivan Minčík <ivan.mincik at gmail.com>:
>> The same unusable error message with make -j1:
>> HTML reference in directory ./html/index.html make[1]: Leaving
>> directory `/home/pkg-grass' for dir in lib gui/wxpython ; do \
>> make -C $dir htmldox-single ; \ done make[1]: Entering directory
>> `/home/pkg-grass/lib' make[1]: *** No rule to make target
>> `htmldox-single'. Stop. make[1]: Leaving directory
>> `/home/pkg-grass/lib' make[1]: Entering directory
>> `/home/pkg-grass/gui/wxpython' make[1]: *** No rule to make
>> target `htmldox-single'. Stop. make[1]: Leaving directory
>> `/home/pkg-grass/gui/wxpython' make: *** [htmldocs-single] Error
>> 2
> should be fixed in r63433. Please could you try to compile trunk?
> After some testing I will backport it to relbr70. Thanks, Martin
Currently I have no time to try it in latest trunk, but I have applied
your fix in to the version I am testing (which is latest failed
version from Launchpad - grass70_7.0.0~ppa~2~revno-31311) and it seems OK.
Ivan Minčík
ivan.mincik at gmail.com GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJUhX6XAAoJEPfdLsR5UpoeGj0H/0KwPNt6/2F14P4GS9Sv6MP3
+FwLK7mz9/T9JfsExwTSER39dSKLaK9fW1vm104Cs0Nb691qiJpdDh7OfScL/D/w
vVUQTpp0U/UAJGQ12z0JDiPZV0WDWw05YIEug63HtRCma6L++RGxno0j9ZNeaWi/
RfAm97iR8XFcuGC2YrPWLAECeW+8l3uGpAro3N8r82Dolu3b5OyBz8xyg09E9Ov8
JIvWb6q0YjYXoo0Yc+royr3tApUyGCJBFsuv0eSAnUxNOMcJFgtVngAG0RVcGU4r
5Wg+JtZxkACpX40RW1YVSRsO+J1q8fCSmm+gmw4r7iPMmNJ7xXIFg5pifYU/t0Q=
=Pdu8
-----END PGP SIGNATURE-----
